assembly of many MUs at once
Hello, dear Community,
thank you very much for all the help so far.
My production line flows as it should finally ;-).
Now, at the final stage before quality control;
I have to assemble many (9+) Components at once,
pick up 1 each and send them to an assembly station
and delete them and create a new MU (the final product).
Do you have a suggestion, with which method I could
do this in an elegant and slim way?
I was considering having a chain of assembly stations, each deleting 1 part but
that feels clunky. I also do insist not to use one of my MUs as a container,
because I want to extend this model later, using containers as conveyers.
Thanks a lot in advance!
Re: assembly of many MUs at once
use the assemblyStation, it is the easiest way (mode: deleteMUs, exiting MU: new MU)
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Beautifully easy. thank you.
