assembly work object not working..
hi all.. in my model entity is not passing through the assembly work object please help me..
3 REPLIES 3
Re: assembly work object not working..
Hey ibrahim,
It appears you are using an Entity that you want to move via a Track object.
This does not work as neither of these objects has a speed defined to them.
Either use a Transporter object in combination with your Track, or use an Entity / Container with a Line (conveyer) object.
Sincerely,
Thank you for your reply.. i was trying to do it in the plant simulation assembly line  not in plant simulation basic..
Thank you.. i got the solution..
