assembyl station
I would like to build a assembly station with 2 main objects as follows:
main object a with subassembly object b (quantity:2)  object c (quantity:3)
main object d with subassembyl object b (quantity:3)  object c (quantity:3) object e (qunatity: 3)
Please can any one suggest solution for these problem
JM
Re: assembyl station
You can for example use the following statements in an entrance method:
if @.name="a" then
    ?.MainMu:=1
    ?.assemblyList[1,1]:=2
    ?.assemblyList[2,1]:=2
    ?.assemblyList[1,2]:=3
    ?.assemblyList[2,2]:=3
else
Thank you.... i will try this solution
