assign a table value to another table
as below picture,the table "t" is created in a method ,and the table tt was created in frame, how can assign the  value of table "t" to table "tt" directly,thank you very much
Re: assign a table value to another table
you could use something similar to the followig code
var t:Table
tt.copyFormatTo(t);
t:=tt.copy({*,*}..{*,*})
Kind regards,
Igor
