calculating part of track empty
I am using Plant Simulation 12.2.1.
I need to calculate if part of track is empty (Without separating  two tracks ) . Is there a way to calculate it using  observed value?  For example After 70 meters see model attached.
Re: calculating part of track empty
You will not find an observable value for this case. But you can use the contentslist of the track for checking the positions of the transporters on the track. See the example.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
thank you very much Steffen
