change layout of company
Dear All,
Is it possible to change the position of all stations with a corresponding connection in one model?
Ex: I already have one default layout model. I want to add one feature like a switch. so, Company owner can easily change the layout by pressing a switch.
Check attachment.
Thanks in advance
1 REPLY 1
Betreff: change layout of company
yes,like in other applications, most of manipulations you do manually , can also
be automized through simtalk ,
e.g. create object , delete object, connect object , set object position , set object parameters etc.
still I guess it is simpler to the modifications manually in your.
I mean, what is the intended source for the modifications ?
A table with modifactions to be accomplished by simtalk ?
