10-31-2015 06:00 AM
Hello
I have a question to rename the item. I have a situation that I would like to part of the warehouse No. 2 received the name of the current item in the warehouse No. 1, from which you should use to accomplish this?
Thanks for answer
Solved! Go to Solution.
10-31-2015 06:09 AM - edited 10-31-2015 06:09 AM
the attribute name sets the name, the method cont returns the actual MU, e.g.:
warehouse2.cont.name:=warehouse1.cont.name;
Steffen Bangsow freelance simulation specialist web: www.bangsow.eu mail: steffen@bangsow.net | ![]() |
11-01-2015 09:22 AM
Thank you for your help, but there is a problem with this method.
When I have to complete Part 1 and Part 2 is thus formed only counts Part 1 and Part 2 as Part 1. That is how I make x10 Part 1 and Part 2 is at the end of Part 1 is x20.
What can I do about it?
11-01-2015 01:39 PM
I do not understand your question completely. Do you want rename the parts, that you need for assemble it?
11-01-2015 02:03 PM
This is the model. Cut the sheet metal parts and the remainder is possible to use for the next job. The rest of the sheet metal is transferred to "Magazine No.2". Sheets of this magazine is picked when it can be to live up to the job. The final result should come out 10 "Elementów Nr1" (Part1) and 10 "Elementów Nr2" (Part 2)
11-01-2015 03:26 PM
11-01-2015 03:36 PM
11-02-2015 02:50 PM
I took advantage of this change to the name and added "deleteMovables" and everything works well. Thank you very much.
