commands in plant simulation to transshipping BEs from vehicle to vehicle on different streets
i need the right arithmetic intruction commands to program this transshipping written in the Subject folder.
1. street called w12
2. street called w21
1. vehicle called vsw1
2. vehicle called vsw2
BEs called A, B and C
If somebody know how to program it, i would be very happy.
If there is any possibility to get a course to learn more how to program in plant simulation 11 please tell my where i can find such a course.
Thank you very much!
sebo
Re: commands in plant simulation to transshipping BEs from vehicle to vehicle on different streets
Hello Sebo, If i understand correctly, you want to move Mus A, B and C on the transporter vsw1, vsw2 on track w12 and w21, respectively. If this is the case, you don't need programming, you can do this by using transferstation object in tools. About programming, Plant simulation inbuilt help will be of great use to start with. Check out these topics in inbuilt help. Reference Help > Simtalk Reference Help > Information Flow Objects > Method
you can access the transporter on the track with track.cont , the MU on the transporter you can adress with transporter.cont, so if you want to move one mu from the transporter on w12 to the transporter on w21 the command is:
w12.cont.cont.move(w21.cont);
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
