comparing division result
Dear Community,
i need some help in something that (should) be simple: i have to divide two numbers. if the results of the division is an integer (for every value and not zero) than do something.
Any suggestions?
Re: comparing division result
Have a look at the mod operator (modulo operation).
If modulo operation equals zero , then the division result is an integer.
