converting 3D Graphics...from .cel to .s3d
How can a 3D graphical object in .cel format be converted to a .s3d format. so it can be used in the Plant Sim Environment?
DSI
Re: converting 3D Graphics...from .cel to .s3d
If you refer to the MicroStation cell definition file format, there is no direct import. But MicroStation can export Jt files which then can be imported in Plant Simulation again.
I am refering to the .cel file generated/used by AutoMod simulation software(ACE..their 3D builder).
The automod cel format will not do .
What other formats can you / automod provide / export,  VRML2 ?
