csv import with comma separator
I need to import CSV file that have comma as column separator. I know that I can replace comma by semicolon by open it and replace all comma by semicolon.
But, is it possible to set comma as column separator for the readFile/writeFile fonction ? If no is it possible to add it ?
PS : I use Plant Simulation 13.2.1
5 REPLIES 5
Re: csv import with comma separator
Hello rpinon,
        It likes that only the following signs are supported by plant simulation.
       (1) Tab (2) blank Space (3) semicolon.
Yes I know... It is why I ask if it possible to add it in plant simulation.
So, if I want to use comma as column separator, I have to develop a parser by my self ?
The object Tablefile has an attribute ColumnSeparator.
Please look at the index of the manual.
Yes, but i can't use it like this => ColumnSeparator = ","
