dealing with arrays 2
Builder
Builder
Why the result of this method is 1 instead of 5?
Re: dealing with arrays 2
In version 12 the array methods 'find' and 'deleteValue' do not work correctly when used with arrays of data type 'any'. It will work if you use a string array.
The bug is fixed in version 13.0.7 and higher.
Builder
Builder
Perfect!!! Smiley Happy
