defect product doesnot change its integer value
I have modelled the machine to generate defect product.
here i have defined integer value 1 for defect product and integer value 2 for non defect..
but it generates only one type , even i have randomised
thank you for your help.
Re: defect product doesnot change its integer value
Hello Cplex,
please use the below program & change the data type of the attribute 'defekt' to 'real'  for the part 'a'.
var defekt : real
@.defekt := z_uniform(1,0,1);
if @.defekt > 0 and @.defekt<= 0.2 then
	@.defekt := 1
elseif @.defekt >0.2 then
	@.defekt :=2
end
Thanks & Best Regards,
Abhilash Sridhar.
Abhilash Sridhar
Mercedes Benz R&D India, Daimler AG
I have changed the names of the variables:
var rand : real
rand := z_uniform(1,0,1)
if  rand <= 0.2 then
	@.defekt := 1
else
	@.defekt :=2
end
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
