05-30-2016 02:20 PM
Hello all!
I'm a beginner in PS and I have a little bit of a problem defining component types and structuring my object tree. So I am asking for your help.
I've imported a jt file into PS, then how can I define the components? (as clamps, device ...and others?). Before I've tried to insert each component and to define them before but when I want to create a kinematics I can't because they are not in the same component structure.
How can I create kinematics and in the same time to have a very well structured Object tree?
Thank you in advance!
Solved! Go to Solution.
05-31-2016 03:14 AM
Hello vasi,
This is the Plant Simulation forum, but it seems your question refers to Process Simulate.
So, if you want to make a kinematic simulation, you should state the question in this forum:
https://community.plm.automation.siemens.com/t5/Tecnomatix-Robotics-Forum/bd-p/Robotics-Tecnomatix
05-31-2016 03:31 AM
Sorry! I am new, so i didn't know very well how it works! Thank you!
Best regards,
Vasi
05-31-2016 04:18 AM
@ALL
I am not sure if PS stands for Process Simulate or Plant Simulation.
In any case setting up a usefull structure for kinematics /simulation (from an imported geometry) is also
possible in Plant Simulation ( s.pic b. + video)
more
05-31-2016 04:45 AM
Hi! Thank you for your reply!
I ment Process Simulate..sorry for missunderstanding.
Have a nice day!
