delivery table normally distributed
Hi to everyone,
I chose for a source "time of creation: delivery table"
The monthly production is normally distributed so in column 3 I used " z_normal " for all the months, but when I start the simulation it create only 1 MU per month. Is it possible to solve this problem? Thanks
Re: delivery table normally distributed
why you don't put the distribution formula directly in the source?
In the tab attribute of source you can select fomula in the menu for interval and type the distribution formula.
If you don't know the formula, use the data fit tool.
