different workers each shift
Builder
Builder
i have a situation where my model runs for one week.Each day have 3 shifts and each shifts have different number of workers every day.worker change every shift and also every day.How can i change the number of workers in the workerpool according to the day and shift??
any help??
21 REPLIES 21
Re: different workers each shift
you can not load worker dynamically during the simulation run. The workerpool will be filled at the start of the simulation according to the creation list of the workepool.
One way to solve your problem is to create each individual worker in the class library and assign to each worker a individual shiftcalendar. Then create all worker in the workerpool. The individual worker will work only in their working times.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Builder
Builder
Hi Steffen_B
Number of workers is not fixed each day  every shift.Morning shift today can have less worker then morning shift tommorrow.how can i solve this situation,if i allot the shift to the worker it will be same for each day but it can be different different day .
help??
How do you want to control this? Do you have a schedule for the individual workers?
Steffen Bangsow
web: www.bangsow.eu
Builder
Builder
i have the schedule something like this
only an idea. You can set the shiftcalendar dynamically with shiftcalendarObject in the workers. You could create 4 shiftcalendar objects (each only for one shift and one without working time). Create 15 workers in the workerpool. Then you set at the beginning of the shift the right shiftcalendar for the number of workers, all remaining workers get the shiftcalendar without working time...
Steffen Bangsow
web: www.bangsow.eu
I made an example:
http://www.bangsow.de/detail_en.php?id=687
look in the observer of the object ShiftCalendar
Steffen Bangsow
web: www.bangsow.eu
Builder
Builder
Hi Steffen_B
Thanks for the solution,but i am not able to understand the functioning.When i run the model in night shift on tuesday as shown in the figure,there seems to be 15 workers,but according to the table it should be only 4 workers.It seems something i am missing to  catch.
To detect the shift change I have included in the shiftCalendar object between the shifts one minute unplanned time. Unplanned is observable. The control is in the ShiftCalendar - Tools - Observers. I observe the attribute unplanned, look for the day and the shift und set the shiftcalendar in the workers:
(attribute: string; oldValue: any)
is
 d:string;
 shift:string;
 days:string[];
 numWorkers:integer;
 i:integer;
do
 days:=makeArray("Sunday","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday");
 if oldValue=true then
  --start of new shift
  shift:=self.~.getCurrShift;
  d:=days[dayOfWeek(eventController.absSimTime)+1];
  numWorkers:=workers[d,shift];
  --set the shiftcalendars
  for i:=1 to .resources.worker.numChildren loop
   if i<=numWorkers then
    .resources.worker.childNo(i).shiftcalendarObject:=str_to_obj(shift);
   else
    .resources.worker.childNo(i).shiftcalendarObject:=nothing;
   end;
  next;
 end;
end;
To set it for the start of the Simulation, set the start-time of the simulation 2 minutes before the start of a shift:
You can reset the statistics then after two minutes to delete the "warm-up" results.
The unplanned workers have a blue icon.
Steffen Bangsow
web: www.bangsow.eu
Builder
Builder
when i see in the model the number of workers is more as per the worker table.is it happening because of warm up??
