discharge vehicle at sensor
i want to discharge a vehicle at a sensor point with the following method
(SensorID : integer; Bug : boolean)
is
	TabellenName : object;
do
	TabellenName := (@.name+"_"+to_str(@.id)+"_Bestand");
	if SensorID = 1 then
		while @.voll = true loop
			@.Inhalt.umlagern(Puffer);
		end;
		TabellenName.löschen;
	end;
end;
But somehow my vehicle has the same amount of BEs after passing the sensor. Only the table content is deleted.
I tried various methods like leer = false (empty) or AnzahlBEs > 0 (AmoutOfBEs) but then my programm crashes.
If i don't use a while-loop only 1 BE is discharged.
I hope you guys can help me with my simple question but i don't know why it doesn't work. I know that i can solve this problem with a DismantleStation or a converter (there i don't know where to fit my tablecontent deleting), but i want to solve it with a sensor-method
Thanks in advance
Carsten
Re: discharge vehicle at sensor
the buffer needs to shift the parts, so you need a little delay between the MUs, if you use the contition
only one part is moved, then the condition @.voll returns false.
Try this instead:
--stop the transporter
@.angehalten:=true;
while @.belegt loop
  wait(0.1);
end;
--start the transporter
@.angehalten:=false;
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Works perfect. Thank you very much.
Greetings
Carsten
