error 2503 error 2502
when i try to install the PlantSimulationSetup.msi i am getting error 2503 and 2502.
My System:
Windows 8 (64Bit)
Thanks.
Re: error 2503 error 2502
I have not seen this problem before.
I suggest you run the .msi file as administrator. This might fix the problem.
sry for the huge delay.
I have installed it on my second Computer (win7). it has worked without any Problems.
