error on track exit , transporter not moving forward
hello,
My transporter is getting stuck at the end of track T5, it is  carrying a product with qt=6 and as per the exit control code, it should move to destination T511, but it is stuck up at the end of track.
It is a part of another model, so some tracks maybe missing as it is written in the code. But i am getting the same thing with the whole model, might be some mistake i have done somewhere.
Can someone please tell me what is the error , i am unable to find out why.
Also any tips how can i improve the model with respect to usage of so many exit controls or methods.
Thank You
Best Regards
Ajay
6 REPLIES 6
Re: error on track exit , transporter not moving forward
Hello!
I managed to make the transporte keep moving by simply adding a '@.move' to the end of the entrance control to ControlsA on T6. Unfortunately I don't understand tha cause of the problem, but the @.move should at leas make the transporters move.
i deleted and created the track again, now it's working, i don't know why it wasnt working before when i did the same thing.
btw thank for the tip of @.move
Hello
I found the reason why it is stucked
At LaneA you set exitlocked
be aware @.move in an entrance control to skip the movement through the entrance controls object, so usually this is not a good idea ...
Always consider using the AttributeExplorer!
thanks
will do that and consider the attribute explorer
thank you
