exitcontrol rear of a buffer and multiportalcrane pickup
Builder
Builder
Hi all,
I have a little question : If a crane take a mu from a buffer, does the mu active the exitcontrol rear of the buffer when exited ?
If not, how to ?
Thanks in advance !
Flo
Re: exitcontrol rear of a buffer and multiportalcrane pickup
Hi Flo,
yes, a rear triggered exit control should be called when a MU leaves an object.
Do you experience a different behavior?
Ralf
Builder
Builder
No, not in my mind...
I haven't already configured my multiportal crane in my model, and while coding the exit control of my buffers i just wonder if I could put a method only executed when the mu exits the buffer with the crane ! Smiley Happy
Thanks for the response !
flo
