experiment manager time format
Dear Community,
i'm trying to solve a problem that i have when usign experiment manager (see the image below).
I just want to use the delivery time that i, now, put manually in the table at right bottom corner in the "define experiment" table.
Unfortunately i got an error of date format; i've searched on the help but i found nothing.
Thanks for your help.
Re: experiment manager time format
Hello Francescopoli,
Input values of type datetime or date are not allowed in the Experimentmanager.
I recommend to use input values of type string.
In an init method you can set the date value:
Tablefile[1,2] := str_to_date(Variable)
Your screenshot shows a problem with the object Tablefile. I cannot reproduce this error.
Please describe it in more detail.
Peter
