01-12-2018 08:13 AM
Hello community,
I use a distributed simulation with four processors.
The simulation works fine and after all runs are finished a pop-up appears telling me the simulation running time.
If i want to check the results or detailed results, both tables are empty and neither can i open the HTML-report.
So i checked the protocol at the tab "distribution" showing the attached picture.
The error method shows "Experimentverwalter.Mread.results"
Do you have experience with this error-type?
Thank you very much for your help!
Kind regards
Seraphin
01-16-2018 10:19 AM
Hello Seraphin,
it seems to be that all simulations are executed.
Please try to call in a method:
Experimentverrwalter.EndOfAllExperiments
The tool Experimentverwalter detected some errors, which were reported in column 8 of the shown table.
Select a cell and press the F2 key. A Cardfile object is opened. Search for the word "Error" in that Cardfile.
Peter
