find row in table
Hi all.
with the attached code i want to search a table file for an object and create and object with the data from the table.
my table looks like this
object | x | y
	Tabelle.setzeZeiger(1,1);
	if Tabelle.finden({1,1},..{1,*},"Quelle") then
	Zeile := Tabelle.setzeZeigerY;
	positX := Tabelle[2,Zeile];
	Zeile1 := Tabelle.setzeZeigerY;
	positY := Tabelle[3,Zeile1];
	obj := .Modelle.Netzwerk.Quelle.createObject(.Modelle.Netzwerk, positX, positY);
the code tries to search for "quelle" in the first column. if it finds "Quelle" it needs the information in the same row but column 2 and column 3. and with the information from column 2 and 3 it needs to create an object.
how can use the information from column 2 and 3?
Re: find row in table
if you find something in a table, Plant Simulation moves the cursor to this position, you need only to read the position (zeigerY), so you have some failures in your program:
	Zeile := Tabelle.ZeigerY;
	positY := Tabelle[3,Zeile];
end;
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
