flipping a boolean
So in many languages you can flip a boolean by the following statement:
var = ! var;
So if the boolean var = true, then after the statement it will be flipped to false. Is there something like this in PS? I looked through the help and the forum, but couldn't find anything.
I know I could just do:
if var = true
   var = false
else
   var = true
end
But that is SOOO many lines of code! My RAM is precious you know.
Many thanks.
Re: flipping a boolean
Sorry, I found it:
var := not var
"not" is the same as !
