get where the Mu was generated?
Builder
Builder
is there an attribute in the Mu that tells where it was generated?
for example, in some process I want to identify id the Mu was generated through Source1 or through Source2.
Re: get where the Mu was generated?
I guess there is no default attribute, but you can create your own:
-add a user defined attribute to the MU (e.g. origin, data type object)
- add a exit control to the sources (rear):
@.origin:=?
that's it
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
