getting error in method
i am trying to import excel file and run the method in order to transfer the values in excel sheet into table file.
but am getting error called " DDE Request failed with error code 16393"
error line in the program as follows,
wert:=ddeRequest(kanal,Adresse);
below is the example from steffen,
Re: getting error in method
Have you tried ddeRequest (kanal,"r2c3")
instead of ddeRequest (kanal,"Z2S3")  ?
