how to assemble a part on particular position of transporter
Innovator
Innovator
I have made a new 3d model for transporter and trying to assemble a part on it. But the part is getting assembled somewhere in between the transporter. How to assemble the part at particular position of the transporter..?
6 REPLIES 6
Re: how to assemble a part on particular position of transporter
Innovator
Innovator
I have attached an image. I want the part to be assembled where I have marked in green color
Hello Sahana,
for that you have to right click on your transporter in your class library and click in "Edit 3D Properties". In the window that opens you have to go to the "MU Animation" tab. Here you can set under "Area settings" the orientation and position of the MU on your transporter.
Kind regards,
Igor
Innovator
Innovator
@IgorKunjavskij thanks
Innovator
Innovator
I tried doing this. But the part is still getting attached at the bottom near the wheel.
I'm not certain what exactly you mean with assembling a part.
Is the part an MU that is transferred somehow onto your transporter? Or is it a graphic you want to become part of the transporter?
In any case, I think it might be best if you were able to post your model. Guessing this based on a picture is a bit challenging.
Innovator
Innovator
@PeterKomarek part is the MU.. Anyway I got it done..
Thanks Smiley Happy
