09-21-2017 04:49 AM
Hello,everyone!
I analog a sankeydiagram model,which is attached in the following .when i run the model,the sankeydiagram cannot diaplay,namely it cannot mark in color lines.here ,the sankeydiagram is activated and displayed before i run the model?
What happen to it,please give me some adive,its much better if you paste the modified model.
Solved! Go to Solution.
09-21-2017 12:54 PM
Hi MarkLee,
When I run your model and display the sankey it seems to work:
BTW, you can remove the objects which are not MUs from the 'MUs to be watched' list.
09-21-2017 08:40 PM
