how to look up the methods of the "Cranes" in the Applicationobjects?
Hello, everyone
I wanna  create a small crane model, the easiest way is to use the applicationobjects about "Crane",as is shown in the picture with marks.
There are some special requirements in my model, so it's necessary to modify the methods.However,there is on way to access to the methods .Are they locked or  encryption? How to get them?
Looking forward to your directions!
Betreff: how to look up the methods of the "Cranes" in the Applicationobjects?
Hello Mark Lee,
you are right, the Crane library is locked and encrypted.
Can you please explain what your special needs are? Let us try to solve them using the methods of the crane.
GG
GG
Thank you,sir!
