how to mix solid materials
Master
Master
hi,
i want to mix two solid materials in mixer and the output from the mixer should be one product. how do i do it?
5 REPLIES 5
Re: how to mix solid materials
Use Portioner from the Fluid Group.
Or use the Assembly station, then you can do it with a single object. When using the Mixer you need multiple objects to get what you describe. What to choose depends on the rest of the model.
Gert Nomden
Digital Factory Consultant
cardsplmsolutions.com
Master
Master
thanks Smiley Happy
It would be helpful if you could guide us on how to combine 2 entites say entity1 and entity2, to get one single entity i.e. entity3.
Master
Master
thanks Smiley Happy
Apologies !!! but it would be helpful if you could guide us on how to combine 2 entites say entity1 and entity2, to get one single entity i.e. entity3.
Easy, insert an Assembly station feed it with two flows using connectors. It should work with the default settings.
Gert Nomden
