how to move all MUs every 3 weeks from store to next SingleproC
I am new with plant simulation. and i did't find a similar question. so i hope to get help with creating a new topic.
Situation:  Now there is a Factory A(producing time: 70 s/part) and the lead time is 3weeks.  that means each 3 Weeks schould Factory A delivery all produced MUs(no matter the worker at Factory A working one-shift or 2 shifts or 3shifts, the delivery time should be the same, each 3 weeks) to Factory B, and Factory B received all MUs at the same time.
i read some Books, that suggests creat a generator combined with a Method, but i still don't know how to use it.
4 REPLIES 4
Re: how to move all MUs every 3 weeks from store to next SingleproC
what is your license type (standard, professional...)?
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
professional
then it is quite easy
drag from the information flow folder of the class library a generator and a method into your frame
drag in your frame the method to the generator (it will be defined as interval control)
define in the tab times the start time (first call of the method): 21:00:00:00
define the interval: also 21 days
if the method you need to program the transfer of the parts e.g.
while factoryA.exitStore.occupied loop
factoryA.exitStore.cont.move(factoryB.entranceStore)
end
Steffen Bangsow
web: www.bangsow.eu
thanks steffenWoman Happy
