how to save the model when the software is frozen
ich did some importan change for the model,
but I forget to save it.
now the software doesnt response,
how can I save the model at this time?
Besides, what is the shortcut for save the model? I think if We know the shortcuts, we will save the model more often
Thanks a lot!!!
4 REPLIES 4
Re: how to save the model when the software is frozen
Press and hold the key combination Shift+Control+Alternate for 5 or more seconds. A message box should appear that allows you to save the model and terminate the application.
In case that the window of Plant Simulation is invisible or in the background and cannot be brought to the foreground, press Shift+Right Control+Alternate for 5 seconds. All running instances of Plant Simulation will then display the message box.
thanks a lot! I will try it by next time!Man Happy
Is there a list or reference of all these useful key combinations somewhere?
Open the online help, switch to the tab Search, and enter "key combination".
You will find the topics Plant Simulation 2D Quick Reference and 3D Viewer Quick Reference.
