inherit
Hello everyone,
i want to change the path in a method when it reads excels files. but i cant do this because the inherit bottom in on. How i do changes when the inherit is on??
Re: inherit
Hello Catarina,
on the Edit Ribbon of the method editor you can turn off inheritance of the method code by selecting the Inherit-Button.
Ralf
