initialize of TableFile
Hello there,
Why is initialize method not working on empty table? What is the condition of run the method? If I write few number in the table its working.
Re: initialize of TableFile
I guess the initialize method also checks the xdim-/ydim values.
If one of the initialize range values is set to "infinite" (*), it tries to get the boundary from the set cells (xdim/-ydim)
in the table  to avoid initializing a table with inifinite dimensions.
It works! Thank you
