installing multiple version of plantsimulation
Builder
Builder
Hi all,
I'd like to know if it's possible to install multiple version of plantsimulation on the same computer ? And how to not overwrite the versions by updating of something like that....
Is it the good solution to use differents installation folders ?
Thnaks in advance !
Re: installing multiple version of plantsimulation
Hi Flo_M,
this is no problem at all.
Just install each version in its standard installation directory.
Ralf
Builder
Builder
OK. And can I make co-exists the version 12.0.3 and 12.0.5 ?
You can create a copy of the installation folder before applying patch 12.0.5. Then create a shortcut to the PlantSimulation12.exe in this folder. So you can use both versions in parallel.
Ralf
Builder
Builder
OK !
So it's seems to be a smart idea to copy the existing folder of plantsimulation before updating, in order to open old models in the future and keep the compatibility for users with former versions...
Thanks for the response !
