introductory/basic question
Hello Every one,
I am new to this program and i am even learing it somehow now! so i hope this is not a stupid question.
If i do two exact same files with the same components and variables, might they give different simulation and different report results or will they be the same ?
Kamal
Re: introductory/basic question
if you use some random values (e.g. availability, random distributed process times...), than it may be, that you get different results. You can check in your model the attribute: randomSeed of the corresponding elements. If there are differences (e.g. different orders by inserting into the frame --> other randomSeed - value), than this elements create different  random-numbers and so the results are different.
Another reason can be the setting: tools - increment variant at reset in the EventController. If this is activated and you use random numbers, than each run produces different results.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
