is possible to combine shiftcalendar and production goals achieved
  Hello
I whant to test diffrents scenarios in a modell where one part of the modell will work 2 shift at a faster rate and one part of the modell will work 2-shift at a somewhat slower rate and then will a smaller partial night crew will work this part at a much slower rate. Is it possible to either work all the hours of the nightshift or only work until production goals achieved and then change the status of the shiftCalendar so that the produktions stopps? Is it possible to change ShiftCalendar attribut Unplanned?
Re: is possible to combine shiftcalendar and production goals achieved
Hope, this somehow fits to your needs:
Find the spp attached. The breakpoint for stopping the production - when Goal is achieved - is still activated.
Always consider using the AttributeExplorer!
