loading and unloading from transporter in a track to a line using method?
hi..i'm very new to this software and i encounter a small problem while doing my practice for this software - a simple warehouse network. Is it possible to do the loading and unloading of goods to and from a transporter in a track to a line using method instead of transfer station? could anyone show me an example of it?
5 REPLIES 5
Re: loading and unloading from transporter in a track to a line using method?
first, you should stop the transporter, then you load the content of the transporter to the line. You can use a sensor control to do this (right mouse click on the track...)
Within the sensor control you can access the transporter with @, so your program could look like this:
--stop the transporter
@.stopped.=true
--move the part to the line
@.cont.move(line)
--start the transporter
@.stopped:=false
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
i tried the suggestion but it appears to have this error:
A 'void' cannot accept the method 'move'
#i uploaded my file..perhaps you could have a look
exercise 3 is what i did previously and im trying to use method instead of transfer station to do the loading and unloading
test is the who i tried changing but it didnt work out
Thank you so much for the time and guidance
the code was  for unloading the transporter, see the file for loading parts from a line to transporter
Steffen Bangsow
web: www.bangsow.eu
thank you so much for the guidance...it solve the problem but my transporter could only move 1 box at a time eventhough i set the capacity to be 3... is there anything i should add to the method command to change the amount of loading?
- set the right capacity for the transporter
- copy the move command to move more parts
Steffen Bangsow
web: www.bangsow.eu
