machining stand-by
in a line, how can I send a machine in standby state when the machine upstream (or downstream) is failed?
And how can I turn on a machine after a time “X”?
I hope someone can help me!
Re: machining stand-by
I'm working with plantsimulation12
Hello Claudia,
you can use following SimTalk-code:
machine.energyTargetState := "Standby";
wait X;
machine.energyTargetState := "Operational";
The machine will be powering down with the defined transition time to state "standby". After x seconds  the machine starts powering up.
Kind regards
Karola
