manage the route MUs
Hello!
Who knows how to manage the route MUs if you need to go to the same station twice from different SinglProc (or a lot)
7 REPLIES 7
Re: manage the route MUs
Did you have a look at "setMUTraceRouteMethod(...)" ?
If you want to create objects (SinglePro) and a separate route along which will move MUs and cycle change for each call to SingleProс will have its time
what exactly do you mean ?
I mean, how should the model be built so that the details go along the route. Please see example.
Here's a model with 2 pullcontrols ( mpull for intTwice, mpull2 for Singleproc2)
Plus m2 to provide the individual proctime for IntTwice and back stations.
As you can see, this kind of matrialflow with backloops causes a deadlock
Precisely, it is necessary to write for the SingleProc that he would not pass the part until the item passes the second time through IntTwice. + reset the value after passing.
I think a buffer in the backloop could faciliate the tendensy of deadlocking.
Nevertheless locking/ using  intTwice + back  as backloop for every Mu will considerably reduce
the line performance as you are doubling the cycletime by using these 2 stations twice for ever MU !
