method worker ordenance priority
Re: method worker ordenance priority
Can you post your model? And do you need to use a method (programming)?
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Spoiler
have a look into the model; the first batch I call in the init-Merthod, all other batches in the drain entrance control. So you will process  only one batch at the same time.
I have also simplified your methods. The broker method is not necessary.
Steffen Bangsow
web: www.bangsow.eu
Thank you so much for the willingness to help, it really worked.
