modelling a defective object
I want to modell a scenario where,
a single proce machine process object and certain turn out ot be defective.
How can I model, this using a singleproc.
Re: modelling a defective object
you could add a user defined attribute to the MU class (e.g. ok, type Boolean; default value=true).
In the exit control you "validate" the part; dice a random number and set the attribute ok to false if the value is lower or equal than the random value.
see z_normal, z_uniform etc. for distribution methods
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Hello Mr. Bangsow, can you elaborate with an example.
have a look into this example:
http://www.bangsow.eu/detail_en.php?id=364
Steffen Bangsow
web: www.bangsow.eu
Thank you Mr.Bangsow
