move transporter based on order using FIFO method
I want to ask about how to move transporter based on order. So there is order from customer. Then based on the order transporter retrieve the product from the rack. But the produk that is retrieved using FIFO. The first product that store in rack is the first that is oit. How is the method? I hqve tried bit there is eror.
I do wait for the answer
Thank you
Re: move transporter based on order using FIFO method
Hi Ginalusiana,
let us consider this problem by your other question:
http://community.plm.automation.siemens.com/t5/Plant-Simulation-Forum/how-to-move-transporter-based-...
Peter
