number of trailer
see as the picture  a tugger  train system ,how get the trailer  number of the tractor 47B45464-4BD9-40d7-9C51-6DF7CD54502C.png
Re: number of trailer
Hi @fox
Do you wanna get the number of wagons of your tractor? If so, you can use a sensor with this code:
tractor.PNGGetting the number of wagons
param SensorID: integer, Front: boolean
var rearWagon, currWagon : object
var numWagons : integer := 0
if @.isTractor
	currWagon := @
	rearWagon := currWagon.getRearWagon
	while rearWagon /= Void
		numWagons += 1
		currWagon := rearWagon
	end
        print to_str("This tractor has ", numWagons, " wagons.")
end
Best Regards,
Paulo Araujo
