print doubt
Hi everybody!
I need to print in console the name of the value insted of the value itself after a "for loop" , how can i do it?
have a nice day!
Re: print doubt
try
print "priority";
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Re: print doubt
I dont want the name of the array, i want the name of the variable that.
for example:
x = 1
y = 2
z = 3
priority = [ x, y, z].
after the for loop, in console should appear:
[z y x]
jajajajaja hope u can help me!
Re: print doubt
Hi.. Try This for local i := 8 downto 1 loop print priority [i]; next;
Re: print doubt
Hello
print "[", z, " ", y, " ", x, "]"
The above will print '[z y x]' as you asked, but the x, y and z will be replaced with the values of x, y and z variables.
JamesM
Re: print doubt
if x,y,z are global variables you can print the name of the global variables with
ref(globVar).name
or new syntax
&globVar.name
Steffen Bangsow
web: www.bangsow.eu
Re: print doubt
And... how can i do it if its a local variable and its a part of a array?
Re: print doubt
i guess for local variables there is no other way as to write the names as strings like in the previos posts
Steffen Bangsow
web: www.bangsow.eu
