problem with "find" and "cursorX" function in Table
Hallo,
i have 2 column in table. And i want to find the Ydim of column. There is a function .GetColumnYDim to do this. But when i use find and .cursorX to get the column number. The pointer is alway equal 1. Here is my code:
var x,y:integer
Tabelle.find({1,1}..{*,1},.Modelle.Netzwerk.Einzelstation1)
x:=Tabelle.CursorX
Variable_X:=x
y:=Tabelle.getColumnYDim(x)
variable_Y:=y
And the Table:
The result is X=1,Y=3. But it should be X=2,Y=5.
Re: problem with "find" and "cursorX" function in Table
you find with find the einzelstation1 in cell 1,1, so cursorX is one, that is right
getColumnYDim returns the number of rows in the given column, if you pass 1 --> it returns 3, this is also okay
if you want to read the number of entries in column2 you need to call
Tabelle.getColumnYDim(2)
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
I want to find the column using the object. How can i point to the column whose columnindex is .Modelle.Netzwerk.Einzelstation1?
you can use the Einzelstation1 directly as key for the column e.g.
Tabelle[einzelstation1,1]
Steffen Bangsow
web: www.bangsow.eu
I have already solve the problem with function .getColumnNo
