"Random" Exit strategy not really random
Hello community,
I have a singleProc that has two successors: one is named "IO" for good Parts, the other "NIO" for defect parts.
I want to give a percentage of how many defect parts I want to have, but keep "which part exactly will be defect and which not" random and changing from simulation to simulation.
Therefore I have chosen the exit strategy "random" and have written the percentage 4,76% NIO.
The problem is, when I run the simulation many times, I always get the same output values, exactly the same parts that are set as "defect" at exactly the same simulation times. Can this be changed?
I would like to get random "defect" assignment at every simulation run.
Thank you very much in advance!
Re: "Random" Exit strategy not really random
