removing specific entity from a container
I currently have a pallet(container) carrying an engine block(container) which requires 6 things to be assembled to it.  I would like to load the engine block with one of the items assembled to it then remove the entity for a period before re-introducing.
Currently I am assembling this component prior to loading the engine block to the pallet.  It travels to a dismantle station where I am trying to remove this entity and place onto a pallet to carry to the re-intro station.  The issue is the pallet and engine block dismantle leaving the dismantle station which is not the outcome I am trying to model.
12 REPLIES 12
Re: removing specific entity from a container
you could search the item in the pallet and then (re)move it:
for var i:=1 to @.numMU loop
  if @.MU(i).name="Entity" then
      @.MU(i).move(YourDestination)
      exitLoop
  end
next
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Would this code be an Exit Control?
this could be also an entrance control;
as exitcontrol you will need at the end:
@.move
Steffen Bangsow
web: www.bangsow.eu
I have attached an example.  Perhaps the solution is easier with a visual of the model.
and where is the location of this operation?
Steffen Bangsow
web: www.bangsow.eu
OpA30_1
it is ony tigershark on the pallet?
Steffen Bangsow
web: www.bangsow.eu
right now only 1 type on the block pallet but the Block container needs to hold 6 parts.
and what kind of MU you want to remove ?
Steffen Bangsow
web: www.bangsow.eu
