retrieve orders from stock
I have created a simple model with warehouse in which parts are entered, the stock is registered in a table and then the stock shall be retrieved. For the retrieval process i have created a generator which is triggered at an interval of 1 mins. However, the retrieval process is not taking place as supposed.
I am attaching the model herewith to get a more clear idea on the model. Thanks for help in advance..!!
Re: retrieve orders from stock
you cannot use yPos as position marker for the sequence. YPos returns the y coordiate of the tableFile in the frame. Use a global variable instead, than it will work.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thanks Steffen..!!
