robot on rail(7-axis robot)
Hello
I want to make a 7 axis robot.
I want to load 3 different parts to 3 different stations. By one robot.
However, the distance between stations is too long to be loaded by fixed robots.
So I want to use a 7-axis robot, but I do not know how to attach a robot on a rail in Plant Simulation.
I want to make them sensible.
I attach my file.
Thank you.
Re: robot on rail(7-axis robot)
You cannot move the PickAndPlace on a track (PickAndPlace is not a movable unit). So you have some options: use a movable unit (transporter) or try to move the pickAndPlace itself (e.g. by changing its y and x position). There are several discussions in the forum, e.g. look here:
https://community.plm.automation.siemens.com/t5/Plant-Simulation-Forum/move-pickandplace/m-p/402056/...
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
